08-06-2021 01:52 PM - edited 01-06-2022 03:02 AM
08-06-2021 02:23 PM
@Anonymous wrote:@Anonymous
yeah i see you did two time so where is issue now
@Anonymous : There's no issue now. The brief interaction is over. For the sake of unwritten etiquette...good for you.
08-06-2021 02:12 PM
No need to contact customer service. Remove your autopay. Your next renewal will fail. 90 days after that your account will be deactivated and cancelled. Or remove autopay and port your number out that will automatically cancel your service and account.
08-06-2021 02:07 PM
@Anonymous
08-06-2021 02:04 PM
@Anonymous : Like I said before...there's no rule. I edited my post above.
08-06-2021 02:03 PM
@Anonymous
i put it a update and name or you need to put a Edit:
08-06-2021 02:00 PM - edited 08-06-2021 02:03 PM
@Anonymous : How is that the _only_ way when you just provided a way? ???
Edit: aaand there's the edit. Oh and an update mention. Better.
@JUNHO : this is a prepaid service. You don't pay, it stops. In effect cancelling. You can also "cancel" by porting your number out.
08-06-2021 01:56 PM - edited 08-06-2021 02:02 PM
@JUNHO wrote:I would like to cancle My plan.
Support team contact me please.
just remove your autopay,
update @JUNHO the can't contact you
you have to contact them by Customer Support Agent by CS_Agent,
you Have To Submit a Ticket To Customer Support Agent by CS_Agent,
Here’s how to contact Customer Support Agent by CS_Agent,
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Service by CS_Agent. Click Here to get started.
- or you can send a private message to Customer Service by CS_Agent, by Click Here.
- You’ll need to be logged in to your Community account for the link to work.
- please include in your message,
- your account number,
- your phone number,
- your account 4 digit pin,
- your Email address,
- Customer Service by CS_Agent, will Response by private message to you inbox
Good Luck
08-06-2021 01:55 PM
If you have autopay setup then remove your credit card to cancel your account.
