Cancelling my plan.
04-06-2022 12:54 PM
04-06-2022 01:13 PM
HI @BeachNBeer from my observation with what happened on the Community lately , I think there could be "old" member willing to take over an old and clean Community account as well. 🤣😂
04-06-2022 01:10 PM - edited 04-06-2022 01:12 PM
@hiLeah One other option. If you don't plan on porting your number out to another provider. If you're on old rewards program maybe someone here will want to take over your account since all new accounts are PMs new point system.
So if you're not keeping your number and not porting out to another provider maybe make a new thread offering up your account.
First make a new fake email on Gmail/Hotmail and contact support to have the email address changed to that. Then log into your account change your personal info (can put name as Santa Claus if you want and a fake address) and also remove your credit card. You can even change the phone number.
Then give the account to a member here. They will take over it and simply change the sim card to one that they have and either port there number in or change the number again to something else. Then they'll contact support to change email,etc.
This way another member can enjoy the old rewards system 😁
04-06-2022 12:58 PM - edited 04-06-2022 12:59 PM
- Remove autopay. On next renewal your account will be suspended due to no pay. In 90 days of no payment your account will be closed - deleted - number lost
- Remove credit card info (just in case)
- Port your number to another provider. Your account will be immediately closed. Still I advise to do 2 points above, just in case as glitches happen and people get charged afterwards..
04-06-2022 12:58 PM
To be on the safe side, if you are porting your number out also go into your self serve and disable autopay and remove the card you have on your account for payment.
04-06-2022 12:58 PM
What you will need to do is remove/disable autopay (If you have it setup) and just let your plan expire. It will not renew and go into suspension. After 90 days of non payment your account will be closed. Or if you port out to another provider your account will be closed.
04-06-2022 12:57 PM
It being a prepaid provider all you need to do is stop paying. Or port out. Log in and remove any credit card and if you don't have a balance then it will suspend at the end of the already paid period and then after 90 days the account will no longer exist.
04-06-2022 12:56 PM - edited 04-06-2022 12:57 PM
You can close your plan by porting your number to another carrier or going into self service and turn off autopay. If you turn off autopay your account will be close automatically after 90 days from your renewal date.
04-06-2022 12:56 PM
@hiLeah there is no need to formally cancel the plan.
Just login to My Account, disable Autopay and then remove your credit card. PM will not be able to take out money for renewal in the next cycle. Your account will ten be suspended. 90 more days, your account will then be close permanently
