02-01-2023 08:11 PM
Hi, how do I cancel my plan? I am unable to log in self serve, I don’t remember my email or password.
My Account
02-01-2023 08:20 PM
Some people aren't reading what you wrote.
Another option is to pause your credit card overnight of your renewal date. It will go into suspension and then 90 days later it will be fully cancelled.
02-01-2023 08:16 PM
@Help123 - call 611 from your public mobile device to remove Autopay (or call # 1-855-478-2542 or # 1-855-4PUBLIC). After 90 days in nonpay status, your account will be closed.
02-01-2023 08:13 PM - edited 02-01-2023 08:18 PM
@Help123 @If you’re porting number out it will cancel automatically otherwise login and disable auto pay. You can also get support to remove cc info right away this to will cancel
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here
- you can send a private message to our CS_Agents by clicking here.
Edit you can try change password and use all emails you remember having used in the last and see if one you’re still using gets a response to reset password . Otherwise you will need support to regain access to get account number if you do want to port
02-01-2023 08:13 PM
Hi @Help123
submit a ticket with SIMon Chatboth
typ: forgetting information
and Click, Forgot My account Email
then Click, Contact Us
and, Click here to submit a ticket.
or send a private message to CS_Agent
here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
02-01-2023 08:12 PM
To "cancel" the plan, you can either port out your number to another provider and your account will be closed upon successful port out of the number
Or you can also login to My Account and go to Payment page -> Manage Payment Method, and then disable Pre-Authorized payment. PM will not be able to renew your account on your next renewal , your account will then be suspended on that day and 90 more days, it will be closed
https://selfserve.publicmobile.ca/en/account/payment/manage-card-summary
