Activation of a new SIM card on the same phone
tom01
My Sim card is defective. I am unable to use the phone or text message. I have a new SIM card. After logging in to my account scrolling down to change the SIM card, I put the new Sim card number in and when I push save the numbers of the new Sim card disappeared. I have done this five times. Can anybody help me, thank you
17 REPLIES 17
@tom01
Why are you changing the SIM card?
What makes you believe it was defective?
@tom01 wrote:
What is an incognito web browser mode?
It's an enhanced privacy mode that allows you to use websites while saving less information to your device. It also helps to get around issues of a site showing outdated cached content.
@tom01 - what is the current status showing in your My Account?
HI @tom01
did you check your Community inbox?
message them again for status update
usually they reply 2 or 4 hours, if over 24 hours, likely they missed it
tom01
I opened up a ticket yesterday. I haven’t heard anything yet.
HALIMACS
@tom01
I think a primary question to answer here is, what makes you think your SIM card was defective to begin with?
@tom01
Get a public mobile payment voucher from one of the locations below and dial 611 to apply it to your account.
LoveNature
Hi @tom01
open inPrivate mode,from computer. Login and go to your profile and change SIM card number and save it. and insert in your device.
HI @tom01
then open ticket with CS agent and they can help.  You have enough time before you renewal
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
tom01
tom01
I have already tried my laptop with no success
tom01
My payment is due in a couple of days and my account is active
@tom01   try Incognito mode on laptop again
If that does not work , I guess you need PM support to help
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
@tom01 - you mean the sim card is defective because it won't save?
If you have your My Account listed in lost/stolen mode, then go and find/resume services. You may need to make a manual payment to reactivate the account to make the account Active.
Then log out, and log back in.
Now, can you do the SIM swap in your My Account?
tom01
I use both first my mobile, and then my laptop.  The result was the same.
Log out and then try again after logging in using incognito/private web browser mode.
@tom01 were you using your mobile phone to access the Change sim page?  there is an error with that using Mobile device to access
Please use a desktop or laptop computer to access the page and it will work
