07-11-2024
09:41 PM
07-12-2024
01:11 AM
computergeek541
Hi all, is it possible to cancel the ordered physical sim to esim. Just subscribe few minutes ago.
07-11-2024 09:44 PM
HI @Ipoy
it likely is hard to do it yourself without PM support's to help
if you can log back into My Account using the app, then you cannot order esim yourself
but you can ask PM to generate the esim QR code for you, just submit ticket by message using this link:
07-11-2024 09:44 PM
You'll need to contact customer support to have them cancel it for you. To contact support you can submit a ticket through the chatbot by pressing the chat bubble in the bottom corner and typing in "submit a ticket" and selecting "Contact Us".
If that doesn't work you can message support directly from here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
