Cancel Plan
Greengang
I have a public mobile account with 2 mobile plans attached to it. I want to cancel the main account phone plan but keep the 2nd phone plan account. Is this possible without cancelling both and starting new?
Thank you,
17 REPLIES 17
darlicious
@computergeek541
Thanks! Its more than just opinion its highly improper. So is the confusing messaging calling autopay "pre-authorized payment".
@darlicious wrote:
@computergeek541
Is this a glitch? Hopefully at the top of the fix it now list?
I don't have information about if it's a glitch or not, but Public Mobile is aware about the opinion of some members about this.
darlicious
@computergeek541
@dabr wrote:
@Greengang    Apparently PM now requires you to contact them to have any payment card removed (since yesterday's new self serve account update).
Submit a ticket via chatbot and ask them to remove the card and cancel your account as you no longer need it.  Here's a link to chatbot:  https://www.publicmobile.ca/en/on/get-help
If unable to submit a ticket, send a private message to CS_Agent here:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Unfortunately the above is true, and I can confirm that customers are required to contact a customer support agent to remove a credit/debit card from an account.
darlicious
@dabr
Thanks. I posted option #1....put the card on hold for the 12 hours from midnight eastern on day 30 til noon eastern on the day of renewal.
Option #2....If you can access your self serve account then use the spent visa gift card trick used to recieve the $2 autopay reward. I have extras for anyone who needs one.
@darlicious   Yes, I only became aware of it a little while ago when @benfatto linked to this thread regarding the payment card removal:  https://productioncommunity.publicmobile.ca/t5/Get-Support/Remove-Credit-Card/m-p/845058/highlight/t...
darlicious
@dabr
What?!! The wording of pre-authorized keeps appearing everywhere and that is not correct in a legal sense....where did this info on removing payment info has to be done by customer support? Doesnt that defeat the pupose of giving us more control over our accounts?
@J_PM
Greengang
Yes, we do have separate emails and passwords. I think my best bet is to deactivate autopay. I have automatic account withdrawal. If I cancel are there any penalties?
Greengang
Yes, I did read something about the "autopay". Where do I find that?
Greengang
Can I not just cancel it instead of waiting for the account to deactivate?
Greengang
Thank you. I will have my son log in because he does have his own email and password. I want to keep my phone number and transfer to a new provider. I'm assuming public mobile doesn't get involved in any of that process, correct?
darlicious
@Greengang
Did you activate these two plans/accounts at the same time and use the same email? Can you access each account or only one of them? You will need to contact customer support with a secondary email so they can be separated and then you can remove the payment info from the unwanted account.
If you activated them before January 25th of this year and have the old $$ rewards program on both then someone you know or a member here may want to take over the account that you no longer want. Otherwise it will be cancelled and deactivated 90 days after the last paid day of service.
Timer
@Greengang
yes possible the service in here is prepaid and each account is separate from other,
if your number need to port out you need your account is will be activa and remove the autopay from that account and when you port out then that account will be automatically closed.
@Greengang
Each separate account should have its own email address.  If you have two accounts to one email address, you will need to contact customer service agent to separate the accounts and then help cancel one of the accounts.
MrSpock
@Greengang you can only have one account per phone number if you don't remember an email for one of them you will need to contact a cs agent   you will need to open a ticket, to speak to a customer service agent    Click here or if you are having issues with Simon you can send private message to a CS Agent here:   https://bit.ly/2GGCJzH
dabr
@Greengang   Each phone/number/account is separate from each other at PM.
Remove your payment card or don't add any more funds to the account you don't want and 90 days from suspension of non payment, that account will close and number deactivated.
