Canadian phone no
DL4
I am attempting to activate my SIM card It won’t accept my current phone number. Says must be Canadian no. My no is 807-276-xxxx It is a Canadian no
@DL4 ... add to @computergeek541 comment, your number can only be ported over to Rogers  Bell, Shaws, Distributel, ExaTel, TBayTel or their sub-brands
For the technical reason why your number can't be ported to Public Mobile, that's because Telus Mobility doesn't have its own phone numbers for your city of Fort Frances.  Unfotunately, you will not be to port this number in due to number portability rules.  For reference:  https://cnac.ca/data/COCodeStatus_NPA807.htm
@DL4 - check your number to see if it can be ported here"
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
Telus owns both Koodo and Public, so it is okay it says Koodo.
If the number is portable, try the activation again through a tab in incognito mode (if you haven't entered any payment info yet).
