Account number
novelbarrant
need to get my account number with public
@Remember wrote:
@novelbarrant
if can't Login to your account, open a ticket with PM CS_Agent. at : https://publicmobile.ca/chatbot.
type: Contact Us and Other
Finally Click here to submit a ticket
If you have error submitting a ticket, send a private message to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
check inbox(top right corner envelope icon) for response from CS_Agent.
At this point in time, without knowing if there is any account issue or if the customer was succeful at finding an account number, there isn't any reason to contact a CSA.  This would potentially be a waste of the customer's time and it will also slow the the service response time for all other customers.
Remember
@novelbarrant
If you received an activation email with you activated with public mobile, check the TO line of that email, the account number should be listed there as well @novelbarrant
will13am
@novelbarrant , to get the account number please login to the self serve account, click on the profile tab and the account number information should be on the right side.  Hover over the eyeball to reveal.
 @novelbarrant
just login My Account, Profile page:
https://selfserve.publicmobile.ca/en/account/my-profilehttps://selfserve.publicmobile.ca/en/account/my-profile
