03-22-2024 05:32 PM
I have a plan that is labeled as canada-us and I was wondering if I still need to buy the roaming add-on for being in the states
03-23-2024 12:16 AM
I have an iphone 14 - outside of activating data roaming from the settings, are there any APN settings required to ensure data works?
I wasn't able to get my phone to work in Seattle despite despite having similar Can/US data plan - granted I was on auto connect with providers. Will try manually connecting on my next trip.
03-22-2024 05:38 PM
All right that's good to know, thank you very much
03-22-2024 05:33 PM
HI @NitzA No you don't
the Can-US plan allows you to use PM service (data/voice/text) like you are in Canadfa
you just need to turn on Mobile data roaming on the phone, and connect to either T-Mobile and AT&T netowrk. If automatic connect does not work, then manual connect to one of them
