03-22-2024 11:54 PM
Cannot receive or make calls while I am in USA. It rings once and quits. I have powered off my phone several times but still no success. I am trying to get thru to a customer care agent but no reply?
Service
03-23-2024 12:29 AM - edited 03-23-2024 12:30 AM
Hey @Sylvia221959 Couple questions. Do you have a plan that is Canada/US based? If not, did you purchase a US add on? If you do have a Canada/US plan or purchased a US addon, try going into your network settings and turn off automatic and choose T-Mobile. Then reboot, see if that works. It worked on mine.
03-22-2024 11:58 PM
Hi, which phone plan do you have? Does your phone have VoLTE?
Agents typically reply with 2-4 hours. They are closed now their response should be received in the morning.
If possible, put your phone to 4G/LTE and connect to T-Mobile or AT&T.
If calls still don't work, put your phone to 2G and connect to T-Mobile. From the settings menu, turn on data roaming.
