Canada- Us plan
02-24-2024 02:24 PM
If I purchase the Canada - Us promotion plan of $40 / month will it matter if I am in Canada or Us when I call, text, etc. to Canada or the Us.? Or do I need to add on US roaming.
Plans
02-24-2024 02:28 PM
It's called a Canada-US plan because it services both countries.
If it's a Canada only plan, then you'd need to purchase a US Roaming add-on when needing services within the US.
Make sense?
02-24-2024 02:28 PM
@Sav60 Absolutely Yes you can use in both countries it’s a true snow bird plan
02-24-2024 02:28 PM
Calls, text, and data works if you are in Canada or the US... See the fine print here, which states this.
⁺⁺Whether in Canada or the US, this plan includes unlimited calling, text, picture and video and messaging to phone numbers within and between Canada and the US. Data can be used in both Canada and the US.
02-24-2024 02:27 PM
@Sav60 That’s the beauty of it , you can use it in both countries no worries at all
02-24-2024 02:26 PM
@Sav60 the plan allows you to use full service in both Canada and USA, voice and data
