08-06-2020 09:08 PM - edited 01-05-2022 12:43 PM
Hello!
Is it possible to deactivate my voicemail and activate it sometime in the future if I ever want to have this feature active?
Thanks!
Nela
08-07-2020 09:37 AM
Dial *67*8080000000# to stop your blocked and declined calls from being sent to your voicemail.
##67# to reset.
08-07-2020 04:54 AM
When you get enough identical robotic Japanese voice mails with obnoxious music that started as soon as your greeting picked up, this is tempting... Lol. Just blocked another number today
08-06-2020 10:18 PM
Many thanks for all the suggested solutions!
I wonder how you guys know all this!
08-06-2020 10:09 PM - edited 08-06-2020 10:12 PM
Heh @kselmak all of your steps can be done by simply dialing *004*8080000000#
All missed calls will then just go to a fast busy or endless ring.
Reset to default by dialing ##004# - missed calls again go to PM voicemail server.
But enabling the extended absence greeting is probably a friendlier way to let humans know you aren't accepting messages.
08-06-2020 09:20 PM
If you have Android and go to your call settings, then calling accounts, then pubic mobile sim card, then call forwarding you will have chance to change where your calls go of they are not answered or unreachable.
If you put any USA number there, after ringing your phone the forward will fail and disconnect.
Give it a try
08-06-2020 09:20 PM
credits to srlawren
dial into your voicemail and log in with your PIN.
In the main menu, press 3 (manage greetings),
then 4 (manage extended absence greeting),
then 2 (record a new extended absence greeeting) and record a message that indicates to your caller you are not accepting messages.
Then press 4 to turn on extended absence
Finally, press 5 to dissallow anyone to leave you a message.
08-06-2020 09:15 PM
@nmora , some members use the extended absence greeting option. It is not quite the same as disabling voice mail though. See knowledge base link below.
08-06-2020 09:11 PM
08-06-2020 09:10 PM
08-06-2020 09:10 PM - edited 08-06-2020 09:11 PM
Sorry no
BUT if you set out to forward to USA number it will have the same effect.
Which phone are you using?
