Can/usa plan not working
RemDD
i have Canada/usa mobile plan with Iphone.
But when I go to US, my phone doesn't work as it should be. It says At&T on the phone but I could never get any messages or calls.  Do I have to select roaming manually or something?
thanks.
hairbag1
@RemDD
assuming you have iPhone 8 or better...go in to your iPhone settings > Cellular > Cellular Data Options (Roaming ON)> Data Roaming enabled Voice & Data 5G On or LTE.      If AT&T fails, try to manually select T-Mobile.
These are settings that my Iphone SE are set to and used to work when I was going to us.
colleeno
@RemDD
Yes, you have to turn on Data Roaming. Your phone should automatically connect to T-Mobile, AT&T or Verizon. If it doesn’t, reboot your phone.
If you get a text message from PM about buying a roaming add-on, ignore it. It is sent when crossing the border whether you already have a roaming plan or not.
@RemDD
which model of iPhone?  iPhone 8 and above should work
and your mobile data works?  Make sure you turn on Mobile Roaming Data on your phone.
and try different US networks.  Manually connect and try T-Mobile and Verizon as well. Your voice should work with that.
