Can't use points
10-10-2024 06:45 PM
I can't redeem points in the "my rewards" section because it thinks my account is suspended. The auto-pay didn't work last month and I had to manually pay, everything is good for my subscription now and I'm still subscribed with no issues, according to "my account", but it's still blocking me on the points page. When I follow the link in the error message, it takes me back to "my account", where there are no problems.
Thanks!
Rewards
10-10-2024 06:58 PM
@Eva333 wrote:I can't redeem points in the "my rewards" section because it thinks my account is suspended. The auto-pay didn't work last month and I had to manually pay, everything is good for my subscription now and I'm still subscribed with no issues, according to "my account", but it's still blocking me on the points page. When I follow the link in the error message, it takes me back to "my account", where there are no problems.
Thanks!
So by the looks of it, and I'm just basing this off of what I see here, customer service won't be able to help you until you make a payment. Your account has to be active to be able to use your points. However, if you have enough points to cover a month of service, the system should allow you to do that. However, it's my opinion you need to have an active account to use points.
10-10-2024 06:53 PM
HI @Eva333
try again using Incognito/private/secret mode on the browser
and also, confirm the Autopay is enabled before redeeming. To turn on Autopay , go to Payment, Manage Subscription and check if Subscribed is on
if same, then ask support agent to check
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
10-10-2024 06:53 PM
@Eva333 I would report this to customer service , using orange message icon bottom right corner of screen
