Neo Credit card
Leinad
I moved my points over to neo credit card but can't  activate the card with a rural address. How do I get my points back
1 REPLY 1
slusagm
you might need to discuss with both Public Mobile and Neo card, but start with PM
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.)  Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
