10-19-2022 03:48 PM
Hello I'm just wondering if anyone has ran into the issue of not being able to update/change there sim card number. My wife lost her sim card wen traveling and so we bought a new one, but everytime I enter it and press save it goes back to wanting me to enter the sim number again. I'm not sure if the website has a bug or I'm missing something but I'm pretty sure I've done the right steps.
10-19-2022 04:32 PM
That did it I used my work laptop and first try it worked and saved. Thanks so much for the help and tips, absolute life saver
10-19-2022 04:32 PM
To launch Incognito mode for Chrome on mobile:
https://support.google.com/chrome/answer/95464?hl=en&co=GENIE.Platform%3DAndroid
10-19-2022 04:21 PM
Can you try desktop mode?
10-19-2022 04:19 PM
I'm using my phone (google pixel 4A, same as hers)
And I'm using Brave. I also tried it on Google but same thing is happening. Could using a laptop possibly fix the issue?
10-19-2022 04:13 PM
@JSandulak wrote:
No I haven't tried the incognito mode, how do you go to that?
@JSandulak are you trying to access on phone or on computer? what browser are you using?
10-19-2022 04:12 PM
It is a brand new SIM card.
I tried it through the My Account. (Using her account)
10-19-2022 03:50 PM
Couple things to confirm, it is a brand new sim card never used? You were trying to change the SIM card from My Account?
It could be a site cache issue. Just try again using Incognito mode to login and change sim card there and see if it works
