Cancel my SIM Order
kamiyaa
Hi, I would like to cancel my sim order please.
Order number is: 311088
Thank you
1 REPLY 1
@kamiyaa   I am not sure if you can cancel the order.  The site said it there it is a non-refundable order
But try asking PM Support, if it is early enough, maybe you can stop it, message them with your order number:
