02-21-2021 01:11 AM - edited 01-06-2022 02:09 AM
Hello folks,
Please help me out.
Since I changed my phone, I can't text to my wife.
I can receive a text from her and still can call each other.
Only problem is not to send a message to her.
We both have any problems with others by text and call.
I don't think it's because of my new phone. Like said, I have no problems with others.
I have restarted my phone a few times but it doesn't work.
Is anyone who can solve this problem?
02-22-2021 10:40 AM
I know the problem has been solved...
But it *might* be possible you forgot to use the Country Code?
+1(555)555-5555
It sounds like you may have only used the area code making it so you could receive texts but couldn't send them.
02-21-2021 07:32 PM
Sorry, I had already set it up with this.
02-21-2021 07:30 PM
Yes, it worked. Since I manually type my wife's number with a message, it has been through.
I have no clue why it happened. Thanks for your help. APPRECIATED!
02-21-2021 07:25 PM
Yes, I already checked the block setting of both phones.
Sorry, I can't find 'clear cache' or 'clear data' of the message app.
Anyway, I don't think this is why because I have never had this for over 10 yrs.
I will try another phone with my sim if I can't find the solution.
Tks.
02-21-2021 02:49 PM
@ahnseong :Did any of the suggestions help fix your texting issue? Let everyone here know how things went.
02-21-2021 09:45 AM - edited 02-21-2021 09:48 AM
@ahnseong wrote:Hello folks,
Please help me out.
I would say Chat Feature setting, by default, was selected. So go into settings and DISABLE it.
Others already mentioned this has a possibility( @Dunkman and @HALIMACS ), but steps are a bit different on my phone.
Ensure this feature is off on your Wife's phone as well, but it is likely on your end since the phone is "new to you".
02-21-2021 08:07 AM - edited 02-21-2021 08:10 AM
If Android, it's likely you have chat settings enabled.
02-21-2021 01:50 AM - edited 02-21-2021 01:54 AM
I guess you have already checked the block setting on your wife's phone??
Also, you can try to "clear cache" the messaging app. Then Reboot try again.
Next to try is to " Clear Data" on your messaging app but make sure you backup all the text first if you have important ones. then Reboot and try.
Another thing to try is to use another Text app like that Google Messages. you can download on Play Store.
Last to try is to put your SIM on another phone and test it out.
02-21-2021 01:36 AM
Probably something setup issue with your new phone. If you put the PM sim card in your old phone, texting to your wife should work. That rules out PM service issue.
Maybe try network reset of phone. Either enable or disable RCS Chat feature on your phone. Another possibility is to remove her contact and previous text thread. Add back her contact and try texting her.
02-21-2021 01:23 AM
@ahnseong wrote:We both use Android.
And like I said, we both have no problem with others.
Can you manually type in the number to text your wife.
02-21-2021 01:18 AM
02-21-2021 01:16 AM
What model is your new phone? Old phone? Your wife's phone?
If using iPhone, it might be an issue with iMessaging. Make sure data is turned on. SMS text option turned on.
