03-14-2025
09:23 PM
03-15-2025
02:46 AM
computergeek541
I switched today from rogers to public mobile about 8 hours ago. I can make calls,but can't receive calls or texts. Anybody know what the problem is? Seems impossible to to contact a human being
03-15-2025 10:13 AM
Hi there,
I've been switched from Telus to PM yesterday, a porting still not been completed yet. Still on Telus network. Would you be able to share the porting assistant team contact # with me?
03-15-2025 01:11 AM
03-14-2025 09:36 PM
Sound like the port was not completed. there is a porting assistance team you can call and ask for update. I can't post the number here, but I will message the number to your community inbox. Please check and call them
03-14-2025 09:25 PM - edited 03-14-2025 09:27 PM
did you reply YES to the confirmation text sent to you by your old provider within 90 mins ? If so, now remove their sim and install Public Mobile sim and restart...does that help ?
added; clipped from Help Files...
https://www.publicmobile.ca/en/get-help/articles/transfer-your-number
