Can’t submit a ticket
billmckechnie
I’m trying to submit a ticket for a problem but it’s not working. Getting a 404 error. How can I submit a ticket?
dust2dust
Not sure at what point you get the 404 but you can also use the pin option rather than the login id option.
Cooperation
Try using a different browser (e.g. Chrome vs. Safari vs. Internet Explorer).  Things might also be undergoing maintenance over the holidays.
Yummy
Public Mobile has web page cache issue so you might be looking at obsolete status. Click on little spinner refresh icons lower down. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
Hollister
@billmckechnie
Try submitting again but clear your browser cache first and then open a new browser window in incognito.
