Can't sign in
YadaBrown
My phone plan is on another email and i'm unable to sign into that account to change the phone plan
1 REPLY 1
HI @YadaBrown
you will need to open ticket with PM CS agent and have them to change the email address for you
at : https://publicmobile.ca/chatbot.
First type Contact CS Agent,
from the list of , choose "Other"
