Can't sign in
MikeM3
When I sign in it's sends a code to a nother numder then mine and it won't let me in my account
hi @MikeM3
yes, you need to login at least once receiving 2FA code via SMS before you will see the email and voice message option.
have yo opened a ticket with PM support agent yet?
MikeM3
I don't get the bottom  part when I try this just the top part
Yummy
Change receiving a code to email and then see what is in your accouont.
slusagm
Ask PM to help.  Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
