06-29-2023 11:45 PM
Receive this message when. I text one number ...You've entered an incorrect number. Please try again. Vous avez entré un numéro incomplet. Veuillez réessayer.
I can receive texts from this number and can call the number Using a Google Pixel 6
06-30-2023 07:32 AM - edited 06-30-2023 07:34 AM
@Dadofgirls If you get messages from them can you reply to it or is it still giving the same error?
06-30-2023 06:53 AM
Thank you..yes it is default Google message app. Tried all of those , still does not work. Could it be on the receivers end?
06-30-2023 12:07 AM
that is an actual person number and not shortcode message?
Are you using the default Google Message app? 9r those third party app that can send SMS text as well, like WhatsApp, FB Message
If you can receive text from him, can you just reply?
If issue persists try to delete all the conversation with this contact first. Next, delete the actual contact of this person from your Address book. Then Force close the message app, clear app cache for the message app. Now try to message this person by manually put in 1 in front of the 10 digits and see if it works
06-29-2023 11:47 PM
@Dadofgirls Are you putting 1 in front of this one number . Or possibly blocked this specific contact / number
