Can't send text out
1oreilly
Can phone but can't send text out
8 REPLIES 8
@1oreilly  - if you are an android user...turn off your Chat Features.
  1. On your device, open Messages .
  2. At the top right, tap More. Settings.
  3. Tap Chat features.
  4. Toggle "Enable chat features" off.
@1oreilly
If you are an iphone user and you turn your data off occasionally, then turn off iMessage and use regular text messaging instead.
To do this, go to Settings > Messages and toggle iMessage off.
If you prefer to use iMessage, then you can perform the following steps to fix the issue:
  1. Connect to the internet using WiFi or Data.
  2. Go to Settings > Messages and toggle iMessage OFF.
  3. Turn your iPhone off completely, then turn it back on.
  4. Go back into Settings > Messages and toggle iMessage ON.
Make sure “Send as SMS” is also turned ON
Yummy
Do you mean SMS does not go out at all or recipient is not receiving it?
Can you receive SMS?
Aaron_munroe5
We’re you able to send text before or did this just recently start also are you able to make phone calls and is just text messaging issues?As mentioned from one of the other people here try taking your SIM card out (while phone is off) and putting it back in turn your phone back on and try and also make sure you are in a area with service
@1oreilly   How long you have the problem?  Was it ever work and just stopped working or it never work since you joined PM?
So, incoming and outgoing calls both work? but not outgoing Text?  how about incoming text?
you can try to clear cache on your Messaging App.  If you are on Android, you might even want to try to use another messaging app like Google Messages.
@1oreilly
also try to reset network settings on an IPhone
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit  Here link,
click Here link,
How to reset network settings on an Android device
  1. Open the Settings app on your Android.
  2. Scroll to and tap either "General management" or "System," depending on what device you have.
  3. Tap either "Reset" or "Reset options."
  4. Tap the words "Reset network settings."
   or visit  Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
for iphone  go to Settings > Messages > To turn iMessage on or off,
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet wifi is on is not going through the Picture or a video Messaging,
you have to do this to is going through you will need to turn your data on to send a Picture or a video Messaging in world-wide,
make sure your Data is on.
and do again Rebooting your phone means to turn off your phone and turn it back on again.to refreshing your network...
CountyDownIeUk
What kind of phone?. Need to know to suggest what settings need to be reviewed.
@1oreilly
can you try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute
4. put it back and power on,
5. toggling airplane mode off/on,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
This is quick and simple,
