11-26-2022 09:39 PM
Hi all.
I have activated my brand new PM account and sim card. I can receive text message. But I can send out.
I'm using iPhone with most updated IOS. I tried other iPhone on this SIM card, still can't send text message.
12-07-2022 02:44 PM
@shadowban Still stuck?
Best settings:
A. Settings >> Messages: iMessage ON; Send as SMS ON; MMS ON >> Send & Receive: should show phone number and Apple id email address
B. Texting should always work “if” you send to a phone number and not an email address and “if” you receive only on your phone number. So in your message settings......send/receive, only check your phone number...leave the registered email addresses unchecked.
11-27-2022 01:59 PM
Try un-checking iMessage and try again. Or when you sent a message hold down the message and click on sent as text.
11-27-2022 11:52 AM
No not working
11-27-2022 09:53 AM
trying signing out and then signing back into your apple id
11-26-2022 10:25 PM
Yes I tried. iMessage works but not text SMS.
11-26-2022 09:50 PM
@shadowbanmake sure you restart your phone after inserting it, if you've done that with no success, it may be that the setup is taking some time, I'll advise that you give it some time
11-26-2022 09:49 PM
@shadowban , do you have the phone set to iMessage by default?
