08-25-2016 08:45 PM - edited 01-04-2022 03:07 PM
Hello,
I recently switched to Public Mobile and can't get MMS to send or receive. I'm using a ZTE Axon 7 phone. I can SMS and use 4G LTE data with no problem but the MMS does not work.
Does anyone have any ideas what I'm doing wrong? It seems odd for SMS and data to work but not MMS. I have included screenshots of my APN settings to this post.
Service
04-12-2020 05:09 PM
My apn is set correctly. My data is on. I can receive pictures in my texts. But when I am sending them it gets stuck on sending for long time. Somebody told me that my file is too big that is why it is getting stuck. Does anyone know the size limit of files allowed to attach in texts
06-03-2019 12:48 AM
Pretty cool! I changed my apn and "voila" I can now send and receive picture messages! Hooray!
02-27-2019 09:59 PM - edited 02-27-2019 10:05 PM
@Ramshackal wrote:Mary found the solution for me. I added another APN and now it seems to work.
I added the following APN to get it to work:
Name: CA - Public Mobile MMS
APN: sp.mb.com
Authentication Type: PAP
APN Type: mms
Thank you @Ramshackal and @Mary_M !! Setting up the "CA - Public Mobile MMS" APN and turning on data (even though I'm not using a data plan) worked for me too. Recently added my wife to PM, using a Nexus 4. This phone isn't listed in the reference APN list of phones so I was flying blind trying to figure out why I couldn't send or receive MMS.
As an aside, there was reference throughout this topic about resetting the network. I was never able to figure out how to do that on a Nexus 4. On my Oneplus phone it's simple, but couldn't find a similar thing in the Nexus menus.
12-25-2018 09:32 PM
I had this same issue and this worked for me !! Thanks so much !
09-07-2018 07:12 AM
Have you recently activated with Public Mobile? I'd check the APN and make sure everything is good. Had similar issue not too long ago when I first signed up.
The APN settings you need are here .. https://www.google.ca/amp/s/apn-canada.gishan.net/en/apn/public-mobile/samsung-galaxy-j1%3famp=1
09-06-2018 07:09 PM
Running I am running a Samsung j16 and I am having the same problems I cannot receive MMS messages and I cannot send text messages I just reset all of my Ford protocols and it's still not working what am I missing
09-01-2018 06:08 PM
I have a asus zenfone 3 I have data I can receive pictures but I cant send them out the APN is correct anyone know the problem.could be?
07-12-2018 09:21 AM
Hey @Chowwder2000,
thank you for reaching out to us !
If your current carrier is Public Mobile, please feel free to send us a private message including your account details. We'll be more than happy to help 🙂
If you are with another carrier, you will need to reach out to them for any account/service related issue as we do not have access to that.
Let us know if you need help!
cheers,
Mary
07-11-2018 11:05 PM
I need help of receiving and sending MMS messages through my carrier. It's a lifeline wireless and I'm using it with a Xiaomi Mi Mix 2. Can you help me?
05-12-2018 06:33 PM
You shouldn't actually need 2 APNs. You can combine multiple APN types into one profile.
Even without a data plan, APN with type = mms is required, and data must be enabled in order for MMS to work.
05-12-2018 05:22 PM
The additional APN worked for me, as well.
This seems to be a hugely important piece of information to publish.
Can someone confirm if the additional APN is required for users who do not subscribe to a mobile data package? I'm wondering if that's why this problem exists and the second APN is required?
11-04-2017 12:45 PM
Mary found the solution for me too.
I have an Zenfone 3 Max, ASUS_X008DC android version 7
I got the phone in august & I couldnt recieve or send mms.
APN: sp.mb.com
APN Type: mms
Awesome. Thanks
This is twice now that the public mobile forum has helped me get my phone working properly.
08-06-2017 04:52 PM
01-25-2017 06:06 AM
01-24-2017 10:58 PM
Based on your wondering I took my phone off Wifi and was able to send pics just fine after that. Obviously not the most desireable fix but I don't send a whole lot of pics.
01-10-2017 11:51 PM
Cant get MMS to work on my Axon 7. I thought it was working before, but I wonder if I was on WIFI everytime I received MMS in the past.
Tried this solution posted. Anyone have any other ideas?
11-28-2016 10:50 PM
No problem, glad it worked for you too. It's a great phone by the way!
Once again if a mod sees this can you please add Axon 7 to the topic title? I cannot edit it.
11-27-2016 02:47 PM
just got my Axon 7 on Friday and just tried to send MMS and failed. did a search and found this thread and it fixed the problem.
thanks.
11-26-2016 01:45 AM
11-25-2016 11:18 PM
I just ported from Bell yesterday using an HTC M8 and was having the same problem. I tried adding the extra APN and it didn't work. I selected Reset to Default and then also overwrote the existing Telus APN. This seemed to fix the issue with send/receive. I was able to delete the other Telus entry without any problems.
I think the issue is due to the "APN type" entry. If edit your existing APN and enter "default,mms" you should be able to use a single APN for both data and MMS.
11-11-2016 09:08 PM
11-11-2016 08:43 PM
I'm no expert. If the 2nd APN doesn't fix the issue, the only thing I can suggest is to remove it and verify that all your settings in your primary APN are setup exaclty as shown here: http://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-setup-data-and-APN-on-my-Andr...
The other phones I've helped people with were a MOTO G, OnePlus 2, and an iPhone 5; they all worked appropriately with the single APN. My ZTE Axon 7 was the only one that required the separate APN.
11-11-2016 06:54 PM
11-11-2016 08:12 AM
11-11-2016 07:24 AM
10-13-2016 09:42 AM
The solution is good as described. I'm a happy Public Mobile camper.
10-13-2016 02:12 AM
If a mod can add Axon 7 to the title of this thread that would be great. Might help more people find this. (I don't see an option to edit that on Mobile.)
10-12-2016 11:12 PM
For your reference, you do not need a new APN. I. Also deleted the new APN and set the fields above in my existing Public Mobile APN. It also fixed the problem.
I think these fields.shoukd be added to the APN setup instructions.
08-27-2016 03:06 PM
I only give credit where it's due, @Mary_M! You and @Shazia_K have had your hands very full the past few weeks and have been awesome at dealing with the increased volume.
08-27-2016 09:56 AM
Stop it, you're making me blush 🙂 @srlawren
Welcome to PM @Ramshackal I'm glad that we got everything sorted out for you!
Mary
