11-07-2018 12:10 AM - edited 01-05-2022 02:25 AM
I have international text on my plan and I've tried everything from adding exit codes and + sign and I just can't seem to get it sent. Just says "message not sent". Help!
11-07-2018 12:46 AM
@Dunkman wrote:
here is another thread about sending international text:
That's right. I forgot about how some other national phone systems represent their numbering. Nice find. So yes OP...if you see what might be an extra leading 0 then omit it and try just the rest of the area code. Just leading...not trailing.
11-07-2018 12:38 AM
11-07-2018 12:12 AM
@kimberlybkorea wrote:I have international text on my plan and I've tried everything from adding exit codes and + sign and I just can't seem to get it sent. Just says "message not sent". Help!
Does the recipient have texting?
Can the recipient accept international texts?
To go to another country, you need 011 then country code (ie. UK is 44) then once there you do the local number.
