02-23-2022 10:15 AM
Good morning,
My credit card is expiring in a few days and I can't access my account to update it because I can't remember my password. Can someone assist? I've tried resetting but you require a password to do so.....which makes no sense. I would appreciate any feedback. Many thanks
My Account
02-23-2022 12:35 PM
@Anonymous
I assume the OP remember and use the email they registered with.
02-23-2022 11:32 AM
If you cannot reset your password (no need to log in to do that!) or cannot provide proper security answer, contact agent ASAP since your renewal is due soon.
Set autopay to handle these renewals.
02-23-2022 11:15 AM
02-23-2022 11:11 AM
Login to Self Serve account and click on Forgot Password. If it fails, contact a CS_Agent.
02-23-2022 10:46 AM
How far you went in password reset process.. you supplied the correct email to get the link to reset?
Did you get the email with the link yet?
02-23-2022 10:27 AM
HI @Laurie_V I think you already tried Reset password link on the page.
If you cannot reset it via there, please open a ticket with PM Support.
Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
- type: Forgot log in information
- Click "Contact Us"
- Click "Click here to submit a ticket"
- you will then direct to another page to open ticket.
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
02-23-2022 10:17 AM - edited 02-23-2022 10:18 AM
@Laurie_V , if you are unable to make the reset password option work, then you will need to seek CSA support to reset the password. Click on the chat symbol on the lower right corner of the webpage and initiate a support ticket. As a final fallback, if you have issues with the ticketing system, you can send a private message to the CSA directly using the following link. Good luck.
