11-23-2016 12:26 AM - edited 01-05-2022 12:50 AM
11-23-2016 09:02 AM
11-23-2016 02:19 AM
Give the PM reps some time, it took me about 9 days from the time I posted something to a PM. They are working on it. Patience 🙂
11-23-2016 01:30 AM
@ltalis wrote:
I did private message them all. Radio silence ongoing...no one getting back to me...
Looks like it's going to be a waiting game ![]()
11-23-2016 01:29 AM
11-23-2016 01:25 AM - edited 11-23-2016 01:25 AM
@ltalis wrote:
Tried it already ^
I get the error message and can't move onto step 5...
Did you private message a moderator directly? It will certainly help speed up the process if you haven't already.
Private messaging instructions: http://productioncommunity.publicmobile.ca/t5/Announcements/Information-required-before-sending-a-me...
11-23-2016 01:23 AM
11-23-2016 01:18 AM - edited 11-23-2016 01:20 AM
Looks like this situation might apply to you:
@ltalis wrote:
I'm starting to see that some new subscribers are finally getting saved from the port purgatory.
I am a health care worker and I need this to be over with as soon as reasonably possible. It's been nearly a week now and still nothing...
Trouble Shooting Guide By @seltaeb1956 :
I was walking around with 2 phones as my Rogers Sim was still working and PM was only receiving texts. I was was in Limbo as I waited for a moderator. Until I figured it out and the Port was complete. .
The fix for me...
1. On PM website top right hand corner I clicked on MY Account
2. On the right click on Create Account
3. Put in the phone number you tried to port over from your old carrier
4. If the number indeed was ported, you'll get a message that says click to send verification.
if the number wasn't ported, you'll get the following error The phone number entered is invalid or you may have created your profile already. I cannot help you if you get this message and you cannot move on to step 5 below.
5. If your number did port, but was in limbo. Put the PM sim in your phone and within a second or 2 you'll should get a text from PM with a verification code
6. Back on PM website, fill in the code you received on your phone.
7. Click Continue and the next tab will ask to create account.
8. Use the email address you used when you created the account when you signed up to the promotion. I used that email address, but any email address will work to create profile.
9. Type in a new password.
10. It will say account has been created.
11. Now Click on MY Account, fill in the fields username name and password you just created
12. Once I logged in, I saw that my number had actually been ported. It hadn't worked previously because I guess I never had an account/profile on PM website. Once I logged in, I did see payment had gone through, my phone number had been ported and within 5 minutes, the PM sim started working receiving text, incoming and outgoing calls began. Rogers sim stopped working within 20 minutes.
All I noticed was autopay wasn't enabled. I enabled it and now I'm working on PM."
11-23-2016 01:10 AM
that is weird... its half ported. I was only in this state for a few hours
11-23-2016 01:00 AM
11-23-2016 12:53 AM
is your phone a dual sim? if so, insert that sim as well so you could at least receive calls/text. Otherwise, use WhatsApp or other online messengers 🙂
