06-28-2023 09:24 AM
06-28-2023 09:51 AM
@mixxingh2 wrote:Having the same issues in Bolton,ON
Can't make outgoing calls/can't receiving incoming calls.. data/text not working
outages in your area:
06-28-2023 09:48 AM
06-28-2023 09:27 AM
First, try to reboot your phone
then change the Preferred network type or Network mode to 3G ONLY or WCDMA only and see if the phone can connects and if calls work
if issues persists, try to click Reset All networks
06-28-2023 09:26 AM
@Don55 more details would be helpful. Did you just activate with Public Mobile, did you get a new phone, etc....
Try 1 or more of the below:
Check for outages in your area:
https://www.telus.com/en/on/outages
06-28-2023 09:25 AM
@Don55 Try resetting network settings see if this helps
