11-14-2016 05:27 PM - edited 01-04-2022 06:19 PM
11-14-2016 08:23 PM
@bragg2000 Some additional troubleshooting to try:
1. reboot the phone,
2. confirm call blocking was not accidently turned on
3. reset all network settings; will require replacing wifi passwords
4. try your SIM in another phone, and yours in another phone
11-14-2016 06:28 PM
Sorry, I thought you were a new subscriber. What phone are you using?
11-14-2016 06:26 PM
11-14-2016 05:48 PM
My friend had a same problem!. Your number is not 100% ported from previous carrier. Get on twitter and ask about this! The twitter PM could respond to you with in half an hour and get your number ported properly.
11-14-2016 05:29 PM
A couple questions. How long ago did you port your number. What is the call display on the other end when you call them? If you put your old Sim in your phone, is it still active?
