Can't receive calls or text - been 10 days
farahuali
Hello,
I signed up for Public on Nov 15. I am still unable to recieve calls or text. I had virgin before and when someone calls my number they are still getting the virgin voicemail. I cannot send or receive text messages. Please advise asap if there is something i need to do to fix this issue.
Thank you for your help
2 REPLIES 2
farahuali
Thanks!
hummuschips
You will need to contact a mod with all the information needed to fix it.
http://productioncommunity.publicmobile.ca/t5/Announcements/Information-required-before-sending-a-me...
