04-12-2018 07:26 PM - edited 01-04-2022 04:05 PM
Hello,
I have just ported my number from Chatr to Public Mobile. Everything seems to be working fine, except that I'm not able to receive any verification messages from Google. I wasn't able to receive those messages when I was on Chatr either, but I didn't expect Public Mobile to have that same issue, since I had seen those messages on my friend's phone. Can you guys help me troubleshoot this issue? I'm at my wit's end!
02-12-2020 06:31 PM
Please check this Community Post:
If it does not work you will need to contact a member of our Moderator Team.
Submit a ticket via the 24/7 virtual assistance SIMon to get this looked at.
Note that you will need to create and/or sign in to the Community for the below link to work.
SUBMIT A TICKET - https://www.publicmobile.ca/en/bc/get-help
04-12-2018 09:47 PM
Wow that's an unusually long port .Glad it's working!
04-12-2018 09:46 PM
Woah, I can't believe it. I just, on a whim, decided to try the 2FA thing one more time before asking the moderator's help, and I finally got the SMS. I guess @Luddite was right after all, the porting was still in progress. Thanks a lot, everyone. Appreciate all of your inputs!!
04-12-2018 09:21 PM
Oh.. okay then. Guess I'll send a PM to the moderator team. Thanks @srlawren
04-12-2018 09:19 PM
Yes I do use Google Authenticator primarily, but I want to keep the SMS option available as well incase I don't have access to my phone. Just recently, I fell down by accident and cracked my phone's screen, and I couldn't sign into my other phone because I wasn't able to access the 2FA app. Had to use my backup codes instead. So, I just want to keep all my options open, in case anything like that happens again!! 🙂
04-12-2018 09:15 PM
@rpthms don't wait, it's been plenty of time for porting from another mobile provider
04-12-2018 09:13 PM
It's been about 7-8 hours since the porting was initiated. I had switched the SIM only after I lost the Chatr connection. Maybe I should wait for a day before reaching out to the moderator team..
04-12-2018 08:26 PM
@rpthms this doesn't really solve your problem, but you could consider switching your Google account to using Google Authenticator rather than SMS for 2FA. I always use GA when available rather than SMS as it eliminates issues like these, or inability to receive a token while travelling, etc.
To take it one step further, I use Authy app (for Android phones, or for iPhones) instead of Google's own Google Authenticator. Why? Becuase I can have it sync between multiple devices, back up the tokens, etc. I can also use the Authy chrome app on my PC to access the tokens there as needed. Highly recommended if you use Google Authenticator tokens.
04-12-2018 07:48 PM
@rpthms Try your chatr SIM. If it still works the port-in is still underway.
04-12-2018 07:35 PM
That's odd, I personally have been able to receive verification messages from google to my PM telephone number. And even quite recently (within the last month). But perhaps there is someone in the forum who has come across this issue as well and will be able to provide some insights. If not, reach out to the @CS_Agent for assistance! Good luck!
