10-30-2023 04:24 PM
Hello community,
I just ported my number a day ago. I can receive calls and use data, but cannot make outgoing calls. I get an error message "7B1" saying my number is not activated on the network.
It's been almost 24 hour since porting, should I wait or contact customer support? Thanks.
10-30-2023 04:34 PM
Thank you.
10-30-2023 04:30 PM
Hi @paulnguyen
It seems the port didn't fully go through. I will send you the porting team number to call to get this resolved. Please be sure to keep an eye on the top right corner where you’ll see this icon show up.
10-30-2023 04:27 PM
@paulnguyen Contact a Customer Service Rep. You can send them a private message at the link below.
You should receive a reply within 48 hours though they are typically much faster. Keep an eye on the envelope icon for replies.
