07-27-2022 04:41 PM
I have US talk/text roaming plan for $15. Texts are working, calls are not. Can't make or receive calls. Confirmed add-on is on account, restarted phone, tried with data roaming toggled on and off. Not working at all.
07-27-2022 04:57 PM
can you pass screenshot of your add-ons in your account is the right one for US data roaming.
you purchased Unlimited U.S. Talk and Text = $15 but no data on it.
07-27-2022 04:47 PM
@Bethwann Likely you are being limited by the 3G network shut down. Manually switch the network to T-Mobile as mentioned above and see if that works.
More details on the 3G shut down: https://www.publicmobile.ca/en/bc/get-help/articles/us-roaming#:~:text=FAQS%3A%20US%203G/HSPA%20NETW...
07-27-2022 04:44 PM
@Bethwann try to manually change the network selection to T-Mobile, do not leave it with Automatic
