06-14-2025 03:55 PM
06-14-2025 04:09 PM
Which country are you trying to call or text?
how are you dialing or text? Ie. what number sequence, etc.
06-14-2025 04:06 PM - edited 06-14-2025 04:07 PM
Depends where you call, long distance calls are not free, you have to buy add-on and PM network cannot call everywhere either
But text to other countries is included. Where you want to text and how you text?? Usually enter the number in pattern
+1 CountryCode AreaCode Number
