03-03-2023
12:55 PM
03-03-2023
12:58 PM
computergeek541
03-03-2023 01:29 PM
@DDM69 wrote:We contacted a CS agent. This morning a Koodo tech support guy fixed the issue. Calling is working now.
Could you please elaborate what was the issue so we can inform other customers with same/similar issue.
03-03-2023 01:12 PM
03-03-2023 12:57 PM
@Kjchase , there appears to be a system level bug that is affecting calling on a number of customer accounts, myself included. Please use the chatbot link to initiate a support ticket. A CSA will be able to resolve the problem for you.
03-03-2023 12:57 PM
There have been issue since Wednesday for some people with both incoming and outgoing calls.
Try to change to 3G only and see if it connects to the network at all with such settings
If that does not help, I suggest you to open a ticket with PM support and let them aware you are one of those, too. Some customers got the ticket to support and got it resolved quickly
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
