Paid for a ux add on but not working
Lizblad
I came to Florida on Sunday and am not able to send/receive texts or calls. I did for a day. I have booted several times.
10 REPLIES 10
Lizblad
I’m giving up and will use my sister’s phone, thanks for all the help
Lizblad
No roaming data
HI @Lizblad
do you have roaming data on your addon?  if you do, download TextNow (voip app) and make and receive calls there for now
When you move around , you might be able to get the 2G signal for voice.
Lizblad
OK... I can now text but not talk. I have an iPhone xr and cannot seem to get it to 2g... it will not downgrade. This is very frustrating.
When something worked on that one day, was that talk? Or text? Or both? There's a chance that upon arrival that there could be one or two "free" calls. I haven't verified that.
But the phone not having the ability to manually select s a likely sign that the phone no longer supports 2G. Or at least auto switch down. I was in an area that required the manual change. I'm back to a previous area that auto switches.
Lizblad
My iphone7 doesn’t give me the option of going back to 2G from 3G.
If you scan for networks does T-Mobile appear? Were you somewhere else on that one day it worked?
HI @Lizblad
Florida connection has mixed reviews from other users
Make sure you are connected to T-Mobile network
For text, you can leave it on LTE and see if it works
But you can also try to change the network to 2G and test the voice calls
Lizblad
I bought text, talk no data. Both text and talk don’t work.
dust2dust
Maybe you're in a poor T-Mobile coverage area. Text should work fine. Talk only works on their old 2G network. Try setting your phone to 2G GSM only for talk. Text will work there too. Did you buy data?
