03-04-2023
09:34 AM
03-04-2023
04:00 PM
computergeek541
I activated my account and transferred my number, yet I can't make a call and receive calls. I was also charged twice in.
First time with this service. I transferred from Roger, and i dont phone services for 3 days. I really disappointed 😞
03-04-2023 10:51 AM
If it is a stuck port, you should still be able to make calls out.
What about text? data?
Is your Roger's SIM card still working?
A few basic troubleshooting advice:
reboot phone
network reset of phone
Try the SIM card in another working phone. Helps determine whether hardware issue versus PM service problem.
03-04-2023 10:49 AM
@Umuhamzah can you not even make calls?
Please try to reseat your sim card (Power off , take sim card out for a minute, then put it back in and power up)
Check if you see any error on the phone status , like SIM not provisioned, No Network, or No SIM
if you cannot even make outgoing calls, it is more than a stuck port issue. Your sim card was not properly provisioned. It is an easy fix on the PM side, please open a ticket with them and ask them to confirm BOTH the sim card was provisioned and for the porting status. Please open ticket using Chatbot:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
03-04-2023 10:01 AM
Sounds like a stuck in port issue .
Will send you porting team number
For live support to fix the issue
Private message . Top of page envelope icon
Additional info on porting
When transferring (porting) your number to any new carrier it’s important to remember to leave the old providers SIM card in the phone until you receive the confirmation text from old carrier @that point you have 90 mins to reply YES to the confirmation text … also when going thru this process the new provider will want you old providers account number and will ask for IMEI number disregard this (IMEI) number as it has a tendency to just cos porting hiccups .. so if your ready to port to pm and already activated a SIM card you can go to your self serve serve profile tab and change /transfer (port) number this can also be done on activation but it’s advised to pick a temp number first then port
