04-15-2023 12:40 PM
I can't login to my account, I reset my password and still can't login.
I want to check my account for calls and data usage.
05-18-2023 06:10 PM
Hi @troytop when you had the blocker on, what error message you got?
And yes, many login issue was because of browser extension
05-18-2023 04:20 PM
I had this problem and tracked it down to an ad blocker. In case this works for others, I disabled Adblock Plus for the following URLs:
04-15-2023 01:07 PM
hi @Meow I don't think yiu need to wait the 20 min
I usually can login immediately after password change
I think just a brown cache problem only
04-15-2023 12:46 PM
After password reset your should wait 20-30 min before trying to log in again.
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
04-15-2023 12:45 PM - edited 04-15-2023 12:45 PM
@Pilch try again to reset amd login using Incognito mode
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
