how do i log in
Corex
I no longer have access to my login email as it was the email from a previous workplace
1 REPLY 1
@Corex
if you know which email address you use and the password, you can still login as the email address is just a login ID, you can still login and PM will send the 2FA to the phone via SMS
But if you really cannot login, PM CS agent can help.
 please open ticket with PM support
