12-20-2022 04:41 PM
I need to renew my credit card on my account but public mobile wants to send me an email to verify my account, I am locked out of the email address that I have on the public mobile account. So I currently can not put my new card on the account. Is there anything that I can do to get public mobile to text me and verify my account instead of sending the email. Thanks
12-20-2022 05:42 PM
....which would give you the ability to use the SMS option to log in. The email address here is just a login id.
You can also use real time payments in some stores.
12-20-2022 05:23 PM
You can get the 2 FA code sent by text if your account is Active. It will not send the code if your account is suspended.
So contact a CS_Agent to have your email changed.
Meanwhile you can purchase a voucher and dial 611 to active your account from these locations:
12-20-2022 04:43 PM
Public Mobile has web page cache issue so you might be looking at obsolete status. Click on little spinner refresh icons lower down. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
If you still cannot log in, ask agent for assistance.
12-20-2022 04:42 PM - edited 12-20-2022 04:43 PM
Have the code sent to your mobile phone instead.
Try logging into your account using a different browser in incognito or private mode instead.
Try using a different device like a computer or laptop instead. Try again.
