03-30-2019 02:32 AM - edited 01-05-2022 04:03 AM
I have recently moved back to Ontario and need to change to a Ontario number instead of having a Alberta number keeps giving me a change number failed message have shut phone off and restarted it a few times and nothing will work can u please help me just paid my bill and can’t change number to Ontario number
03-30-2019 06:43 AM
Login to your self serve you will see change number option also try different browser if that doesn't help then Contact any moderator by private message to help you with the process.
In your private message the following info
* PM account email address
* PM phone number
* Detailed explanation
03-30-2019 03:18 AM - edited 03-30-2019 03:19 AM
@Sami9106 wrote:I have recently moved back to Ontario and need to change to a Ontario number instead of having a Alberta number keeps giving me a change number failed message have shut phone off and restarted it a few times and nothing will work can u please help me just paid my bill and can’t change number to Ontario number
No neeed to restart phone, check phone settings or any stutf like that. Your phone can't cause failures in self serve account. Try again later or maybe try different web browser. Have you changed number recently?
03-30-2019 02:35 AM
If you have changed your number inside of 30 days then you can't change it again until after 30 days.
