11-08-2022
05:56 PM
11-09-2022
12:27 AM
computergeek541
I cannot call out as soon as I do it hangs up. I know after this month I'm changing companies
Service
11-08-2022 08:12 PM
Are you possibly on a plan with limited outgoing minutes?
If so, you can purchase a calling add-on for $5. It gets you 500 minutes, and they never expire.
If you are definitely leaving here, remember billing isn't month to month, it's a 30 day rotating period so be sure to check your account to see how many days are left before you port out. Recommend porting out 3-4 days prior to the end of your current 30-day cycle.
When you do, keep the Public Mobile SIM card in the device until you receive the Port Authorization Request from your newly selected provider.
11-08-2022 07:52 PM
is receiving calls the same issue? data? sms?
you might need to contact CSA for them to do some checking in the backend.
11-08-2022 05:59 PM
Hi @19LISA63 try call different numbers
Try reboot the phone
or try reseat the sim card with a reboot
11-08-2022 05:58 PM
Try putting a 1 in front of the number…also try rebooting, resetting network settings, reinstalling SIM card.
