08-09-2023 01:12 AM - last edited on 08-09-2023 08:40 AM by computergeek541
I tried to activate my e sim porting it from freedom and got a message saying unable to activate e sim. Please help
08-09-2023 02:59 AM
Make sure that whenever setting up and installing an e-SIM you do it from beginning to end using the Mobile App and not the Website for best success.
https://productioncommunity.publicmobile.ca/t5/Get-Support/e-SIM-Activation/td-p/1020154
08-09-2023 01:59 AM
thanks for the quick help 🙂
08-09-2023 01:58 AM
Thank you so much resetting my network settings three times worked 🙂 thanks for the very quick advice !
08-09-2023 01:28 AM
Yes, the iPhone 11 is compatible with SIM.
Your best option is to contact a CS_Agent and ask you why your iPhone can’t activate eSIM.
Private message them now and they will pm you back in the morning as their hours are 9:00am to 10:00pm EST.
08-09-2023 01:26 AM
IPhone 11 should be fine for eSIM.
Did you get to the eSIM installation step? Either the app will ask for your permission to do it for you automatically, or you will get a QR code to install yourself.
If you missed the step, there is a QR code in your Welcome email. Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone
Once you installed the eSIM profile, (or If you got passed that step), try to reboot your phone once.
If it still does not connect and if you have any active sim on the phone , disable them (eSIM/Physica sim) or remove the physical sim. Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetoosh connections, but you just need to add them back after)
if it still does not work, please open ticket with PM support
08-09-2023 01:18 AM
HI I have an iphone 11. i checked the model before with my IMEI number and it says it would be valid for the e sim
08-09-2023 01:16 AM
What us the make and model of your phone?
