3 hours ago
- last edited
3 hours ago
computergeek541
I bought a physical SIM. but it won't let me activate because I said I am using a eSIM but found out afterwards that my phone is not eSIM compatible. I just want to activate with a physical SIM
3 hours ago
hi @Eddie23
you already activated a plan? you choose esim and went through the activation but cannot complete because of the esim incompatible error?
if you have a physical sim now, then just message PM support agent and they can switch it to physical sim for you
please submit a ticket with CS Agent here:
3 hours ago
@Eddie23 since the account cannot be activated, you would need to contact public mobile for assistance.
Message them at the link below. They will reply back same.
