Re: Can - US plan
redjamwings
We have 50gb, Can and USA plans for $34/month.... We cross over into New York state from Ontario this morning, and we're prompted with roaming charges - why?
self solution removed
redjamwings
Thank you, Slusagm
redjamwings
Thank you, Softech
@redjamwings
the message is a default message for everyone with or without roaming plan or roaming add-on.  Just ignore if you have the correct plan.
make sure you have Mobile data roaming enabled on your phone, and connected to T-Mobile or AT&T.  Sometimes, you need to manually connect to both and see which one works better
slusagm
it's normal, you can just ignore it.  Everyone gets that when you are in US
