Can't activate esim please help
Sean-yubol3105
My email is ***@***  please send qr code as I didnt receive one I am unable to proceed
1 REPLY 1
hi @Sean-yubol3105
remove your email address, we are only customers here
and your eSIM, it was installed by the app already.
Can you double check if the PM  eSIM is already showing up on your Sim Manager or Settings-> Ceulluar?
if yes, then you need to manually enable it
but if it is not there you will need to ask PM support agent to help, you can submit  ticket by direct message:
