05-29-2026 02:45 PM
05-29-2026 03:22 PM
Did you activate the SIM on the PM app?
If you did, reboot your phone by powering off then back on.
05-29-2026 02:48 PM
HI @Burny
what have you done to change the sim card number?
did you try update the sim card number on your My Account's Profile page? if you did, please reboot your phone once with your new sim card in the phone
if you cannot login to update the sim card number yourself, or if you have done everything but still does not work, you can ask PM to help. Please submit ticket by direct message:
