Subscription not activated
Mrunalib71
Trying to activate my subscription but keep getting subscription not activated at step 6
hi @Mrunalib71
and for eSIM, can you double check if the PM  eSIM is already showing up on your Sim Manager or Settings-> Ceulluar?
if yes, then you need to manually enable it
but if it is not there you will need to ask PM support agent to help, you can submit  ticket by direct message:
Mrunalib71
Esim
hi @Mrunalib71
eSIM or physical sim?
try reboot the phone and login to app again and see if you can complete the subscription
if not, ask PM support agent to help, you can submit  ticket by direct message:
